Arc |
Allows drawing arc-, cord-, or pie-shaped objects. To use this object, follow these procedures:
1.Select the Arc option on the toolbar of a Screen.
2.Click the Screen to establish the object's initial point then drag the mouse diagonally until the object reaches the desired size and position.
3.In the two cutting edges, there are two points that indicate the object's angle. Drag them to open or close the angle.
4.The initial style of the object is a pie. To change it to an arc or cord, go to the ArcStyle property on Properties List.
