Pan |
Allows moving the content of a Screen with scroll bars in Elipse E3 Studio or in Elipse E3 Viewer, at run time. To use this feature in Elipse E3 Studio, follow these procedures:
1.Select the Pan option on the toolbar of a Screen.
2.Click the Screen to drag it. The mouse pointer changes to the icon .
To use this feature in Elipse E3 Viewer, follow this procedure:
1.Right-click Elipse E3 Viewer and select the Pan option on the contextual menu.
NOTES |
•In Elipse E3 Studio, as well as in Elipse E3 Viewer, the Pan option is always available when using the middle mouse button. •In Elipse E3 Viewer, that is, at run time, clicking Screen objects such as Buttons, Displays, and SetPoints, among others, prevents using the Pan option, because Screen objects capture the mouse pointer's behavior. In these cases, users must use the options available for the Pan option (middle mouse button or contextual menu) only on Screen's area. |
