Set Default Style |
Sets the options configured on shadow and drawing options on the toolbar of a Screen as the default for all other Screen objects to create. To use this resource, follow these procedures:
1.Select the object to use as the template for the others.
2.Right-click the object and select the Set Default Style option.
3.When creating a new Screen object, this object's shadow and drawing configurations are used as the initial configurations for the next objects.
