Query Setup |
To extract data from a database, users must configure a Query on a Section Report. There may be many different Queries for the same Section Report, but only one can be active at a specific moment. To do so, follow these procedures:
1.Configure the DataSource property with the name of a Database where this Query is executed. In this case, "DBServer".
2.Specify the Table property with a query table, which in this case is "Data".
3.Configure the Name property to keep its original name, that is, "Query1".
