Fields Setup |
In this example, four temperatures are created and stored on a Historic object, and this Section Report focuses on these temperatures. In this case, all values read from this Historic object are printed using this Section Report.
To read data from a database, the ideal area is the Detail Area, as it is automatically repeated as many times as required. This way, five SetPoint objects must be inserted in this area. These SetPoints can be linked to a SetPoint that is configured using its DataField property. Here, the following values are used:
•Field1: E3Timestamp
•Field2: Temperature1, as configured on the database
•Field3: Temperature2
