Defining Areas |
A default Section Report, created when a new Section Report is added to a project, contains the following areas:
•Page Header: Area shown in all pages of a Section Report, as a header
•Detail Area: Area repeated as many times as required, it is the body of a Section Report
•Page Footer: Page footer, it works in the same way as a Page Header
There are also these types of areas:
•Report Header/Footer: Areas that are printed only once, regardless of the number of pages of a Section Report. This area appears as an opening or closing of a Section Report
•Group Header/Footer: A group is used to divide a Section Report in equal sets of values of the same variable. This area repeats whenever a group is displayed. In the example shown here, no construction of this type is used. These areas always encompass a detail area
These areas can be inserted on a Section Report by using its toolbar.
