Bar Code |
A Bar Code object allows generating a picture that converts a sequence of numbers and characters into a bar code. This bar code is either a numerical or alphanumerical representation, used to facilitate different processes. This representation is decoded using scanners, pens, or optical-reading devices.
Bar Code
NOTE |
Please check the Style property of a Section Report for more information about the available bar code styles for this object. |
