Configuration
Configuration
The configuration window of a Query Application Hierarchy object, shown on the next figure, allows editing, checking, and viewing the result of a query.
XQuery Editor window
Available options on the XQuery Editor window
Option
Description
Context object
Object used as the root object of a query. Click Select object to open AppBrowser and select any object. This option corresponds to the DefaultObjectPath property of the Query Application Hierarchy object
Check
Checks whether the syntax of the script in the XQuery query option is correct. The result of this check is displayed in the Result option. This option corresponds to the VerifyXQuery method of the Query Application Hierarchy object
Run
Executes the script in the XQuery query option and displays the result of this execution in the Result option. This option corresponds to the RunXQuery method of the Query Application Hierarchy object
XQuery query
Script used in this Query. This option corresponds to the Script property of the Query Application Hierarchy object
Result
Shows the result of checking or executing a Query
The XQuery language used in a Query Application Hierarchy has the following specificity:
Literal Strings are only allowed with double quotation marks (")
Comments must use the VBScript pattern, with a single straight quotation mark (')
The underline (_) character allows continuing code on the next line
The root object, indicated in the DefaultObjectPath property, starts as the current context object (@me) and the first @foreach command traverses the child objects of this context object
The @with command allows executing child commands on a new context object, allowing to access internal collections of these objects
The argument of a @with command is an expression that must return an object
Use the @with command with a question mark (?) character at the end of the line to indicate that the evaluated expression is optional and must not generate an error, such as when accessing an existing collection which may be empty at the time of the query
NOTES
For more information about the specification of the XQuery language, please check the XQuery Language Reference.
A Query Application Hierarchy can also be executed using the XQuery method of the E3Globals module.
Usage Examples of a Query Application Hierarchy
To query child objects of the Data folder from the server of Elipse E3's demonstration application, use the next code.
<{Name}>
  @foreach
    <{TypeName(Me)} Name>
    @recurse
The result of that query is similar to the next code.
<Data>
  <DemoTag Name='DateTime' />
  <InternalTag Name='EnableAlarmingMode' />
</Data>
To access all Links of the Menu Screen from Elipse E3's demonstration application, use the next code.
<root>
  @foreach
    @var Object = {Me.PathName}
    @with Me.Links
      @foreach
        <Link Object Property Source>
    @recurse
<root>
  <Link Object='AppScreens.Root.Menu.hpLyraMenu1.Monitor' Property='Visible' Source='False' />
  <Link Object='AppScreens.Root.Menu.hpLyraMenu1.StartRunning' Property='Visible' Source='False' />
</root>
