Simple |
In a Simple Link, the value in the Source column is copied to the property each time the first one is modified.
Simple Link
To use this resource, follow these procedures:
1.Right-click an object and select the Properties option.
2.Select the Links tab, click the Link column of a property, and then select the Simple Connection option.
3.In the Source column, click to indicate a property to create a reference or write down an expression in this column.
