Block Diagram |
Elipse E3's internal architecture is completely scalable, with each main task executed by a separate service. The following diagram shows an overview of its main blocks.
Elipse E3's block diagram
Briefly, an E3 Server is responsible for creating an executing a process, or E3Run, that effectively executes the application. Within E3Run there are other servers that expose services used by other modules.
