Historic Index
Historic Index
A Historic Index Historic Index object represents an Index of a Historic on a database table. To insert a Historic Index object, right-click the Indexes object and select the Insert - Historic Index option or select the Indexes object and click Add Add - Historic Index on Historic's toolbar. Please check topic Index Field for more information about the Fields that can be inserted in this object.
