Frames
Frames
A Frame object is used to organize and structure a project's interface, creating composed views for users inside Elipse E3 Viewer's or a browser's main window. Many times, an application requires only a main Screen, which is the doorway to an application. From then on, users can browse other Screens, which replace the first one, unifying the process view. However, more than one view in the same document or the same project is supported. This is useful when an application uses a Screen that never changes, or has little changes, such as a menu, and another part that is a Screen's browsing area. To use this resource, follow the next procedure.
1.Right-click a project's name in Explorer and select the Insert - Frame option. In Domain mode, right-click the View - Viewer and Frames item, select the Insert Frame in option, and then the project's name.
Inserting a Frame in Domain mode
Frames have subdivisions, called Splitters, which can be inserted or removed from a Frame by right-clicking the Design tab of the object's view. Initially, a Frame has one main Splitter, which can be further subdivided either horizontally or vertically into two or more Splitters, and so on.
For each new pair of Splitters created by the Split Horizontally and Split Vertically options, there is always a Main Splitter and a Secondary Splitter. Only a Main Splitter has values that explicitly define its position, and a Secondary Splitter gets the remaining value.
So, when a Splitter is subdivided horizontally, its SplitDockPosition property gets the dockTop value. Likewise, if a subdivision is vertical, this property gets the dockLeft value. A Secondary Splitter's property then gets the dockRemaining value, which means it occupies the remaining space.
The Organizer's object icons identify the exact position of every Splitter.
Splitter positioning options
Option
Description
dockBottom dockBottom
This Splitter is below the parent Splitter
dockTop dockTop
This Splitter is above the parent Splitter
dockLeft dockLeft
This Splitter is on the left of the parent Splitter
dockRight dockRight
This Splitter is on the right of the parent Splitter
dockRemaining dockRemaining
This Splitter occupies the remaining space after positioning its sibling Splitter
Every Splitter corresponds to a view of a Screen or Frame of a process, or to a URL (Universal Resource Locator). To use this resource, execute the next procedures.
1.Right-click an open Frame and select one of the options, Split Horizontally or Split Vertically, according to Splitter's type.
Inserting a Horizontal or Vertical Splitter
2.To remove a Splitter, right-click an open Frame and select the Delete Delete option.
3.Users can invert a Splitter's original selection, that is, turn a Main Splitter into a Secondary Splitter and vice versa, using the same menu. In a Main Splitter, right-click a Frame and select the Set as Secondary Splitter option. In a Secondary Splitter, select the Set as Main Splitter option. Splitters' SplitDockPosition property is automatically configured to reflect this change.
4.With the Select Screen or Frame option, users can select a Screen or Frame to link to Splitter's SplitLink property, via AppBrowser.
5.Users can insert as many Splitters as needed in a Frame.
Frame Splitters
Frame Splitters
To configure Frame Splitters, right-click the Organizer on a Splitter and select the Properties option.
Frame configurations
The available options are described on the next table.
Available options for Frame tab
Option
Description
Screen or Frame
Determines either a Screen or a Frame to be opened by a Splitter. It is only enabled if a Splitter has no children. This option is equivalent to the SplitLink property
Zoom
Determines the zoom level in which the selected Screen or Frame opens
Screen Alignment
Determines the alignment of the selected Screen or Frame relative to the visible area
Placing
Determines Splitter's position on a Frame. This option is equivalent to the SplitDockPosition property
Enable scrollbar in Initial Screen
Enables displaying a scroll bar on the selected Screen or Frame
Value
Determines the value to attribute to a Frame. It is only visually effective if modified in a Main Splitter. This option is equivalent to the SplitValue property
NOTES
All Frame options that are available via contextual menu, by using the right mouse button, are also available by using the shortcut key SHIFT + F10, which corresponds to the application or menu key Application or menu key.
The Properties Window of a Frame can be opened by using the shortcut keys ALT + ENTER or ALT + Double-click.
Some Frame or Splitter properties can be configured via Properties List, with no need for creating scripts. To configure any property, locate it on Properties List and perform the necessary adjustments. Descriptions for the properties of this object can be found on the Elipse E3 Reference and Scripts Manual.
