Units |
The second tab on Formula's view is called Units. Units define Tags linked to Formula Templates. Users can create several Units, that is, several Tag groups that can receive Formula values.
Units tab
The available options on this tab are displayed on the next table.
Available options for Units tab
Option |
Description |
Name |
Specifies Template's name |
Unit |
Specifies a Tag to link to this Unit |
This view's toolbar contains the Add option, to create a new Unit, the Delete option, to delete the selected Unit, and the Rename option, to rename the selected Unit. For each new Unit, the window on the next figure is displayed to define a name.
Adding a Unit
