SQL Server Databases |
This is a list of all possible errors that may occur when testing a connection to this Database.
Possible cause
Wrong Server name on a Database Server configuration, or this user has no access to that database.
Solution
Check the server name and if this user has permission to connect to that database.
Possible cause
Wrong user name or password.
Solution
Use a user registered on that database or check the password used.
Possible cause
There is already an object (table, key, or index, among others) on this Database with the same name.
Solution
Change this object's name.
