Oracle Databases |
This is a list of all possible errors that may occur when testing a connection to this type of Database.
Possible cause
Message generated on application log when password or user name is wrong.
Solution
Check if this user exists and if password is correct.
Possible cause
This client connection was not found.
Solution
Check if this connection exists on the computer and if it is working using one of the network utilities provided by Oracle.
Possible cause
There is already a Database object with this name.
Solution
To prevent this error, create and configure different index or primary key names in Elipse E3.
Possible cause
This message is generated when an internal Elipse E3 Query searches for Database objects and does not find them. For example, a Historic table does not exist, thus it must be created.
Solution
This is considered an error only if it persists on application logs.
Possible cause
Whenever there is an attempt to write a record where a field defined as the primary key has a duplicated value, this writing is refused and this message is displayed. Note that a key name is displayed, in this case, SYSTEM.E3INDEX key, as User.KeyName. Depending on the project, this error is expected, but most of the time it is important to check if this key is adequate. These two cases illustrate that situation:
•Power Measurement Systems: Aiming to store all data from a single day, routines used for collecting admit upper and lower tolerances in their timestamps for the collecting process. Thus, some records must be written more than once. In this case, this error is expected
•Alarm maintenance: For this case, there may have been more than one error per second on an application. If the E3TimeStamp field is used as a primary key, there may have been losses of some alarm occurrences, which may lead to a misinterpretation of events. In this case, rethinking a primary key can be the adequate solution
Solution
There are two ways to solve this issue:
1.Users must create a unique index for these key fields.
2.Users must check that application, so that it does not send repeated key values for recording.
