Libraries |
Possible cause
An XControl of a Library that was being used inside this Screen was deleted, or else a Library that contains this XControl was removed from a Domain.
Solution
In the first case, if this XControl was deleted, there is no way to recover it. To fix this error, remove the ElipseX object that is inside a Screen. In the Organizer, users can see an exclamation point over object's icon. On a Screen there is a black square with an X inside it. In the second case, add this Library to a Domain.
Possible cause
Some ActiveX objects used on that Screen were not registered and added to this computer.
Solution
Register and add this ActiveX object by using the Add ActiveX option, available on the Tools menu. For this, users must have an OCX file that contains this library.
Possible cause
This error indicates that the inserted ActiveX control is not licensed in this computer. During the instantiation process, this control searches Windows Registry for its license key (HKEY_CLASSES_ROOT\Licenses) and, in case it does not find it, returns this error. There are development license keys for ActiveX controls, as well as run time license keys.
Solution
To solve this problem, users must purchase a license for this ActiveX control and register it in this computer.
Possible Cause
Probably, one of these Libraries was created as a copy of the other one, and thus both have the same ID.
Solution
For this case, users must remove one of the Libraries from this Domain.
