Historic
Historic
How to disable recording of historic records by scan?
Configure the Interval between records (ms) option on the Historic tab of Historic's properties window with a value of 0 (zero). If users want to perform this by script, the property's name is ScanTime. Thus, values are not recorded automatically, forcing a recording via script using the WriteRecord method.
