Overlaying Animations in Objects |
Possible cause
This new Animation was created without removing the old one.
Solution
To solve this issue, follow these procedures:
1.Right-click the desired object and select the Remove animation option.
2.Apply the new Animation.
NOTE |
Do not try to remove an Animation from an object using the Organizer, because this action removes the object itself. |
