Item, Position, and General Tabs |
On the Item tab, users can view the name of an object and assign a description to it.
Item tab
Each option on the Item tab has a corresponding property. The available options on this tab are described on the next table.
Available options on the Item tab
Option |
Description |
Name |
Determines this object's name. This option is equivalent to E3Chart's Name property |
Documentation |
A free text that enables documenting this object's features and functionality by a developer. This option is equivalent to E3Chart's DocString property |
The Position tab specifies an E3Chart's position on a Screen.
Position tab
Each option on the Position tab has an equivalent property. The available options on this tab are described on the next table.
Available options on the Position tab
Option |
Description |
X |
Defines this object's left horizontal coordinate, in Himetric units. This option is equivalent to E3Chart's X property |
Y |
Defines this object's upper vertical coordinate, in Himetric units. This option is equivalent to E3Chart's Y property |
Width |
Determines this object's width. This option is equivalent to E3Chart's Width property |
Height |
Determines this object's height. This option is equivalent to E3Chart's Height property |
On the General tab, users can specify E3Chart's style and appearance.
General tab
Each option on the General tab has a corresponding property. The available options on this tab are described on the next table.
Available options on the General tab
Option |
Description |
Show title |
Displays this chart's title. This option is equivalent to E3Chart's Title property |
Show title with color |
Determines a color for the text of this chart's title. This option is equivalent to E3Chart's TitleColor property |
Show border |
Enables or disables an external border on this E3Chart, when the visualization of scales is disabled. This option is equivalent to E3Chart's ShowBorder property |
Determines this chart's background color. This option is equivalent to E3Chart's BackColor property |
Paint the grid's background with |
Determines a background color for the grid. This option is equivalent to E3Chart's GridBkColor property |
Refresh rate (seconds) |
Determines an interval between drawing updates in this chart. This option is equivalent to E3Chart's RefreshTime property |
