Column Sort Order |
On default settings, users can sort Alarms by clicking E3Alarm's column headers. When clicking a column's header, the associated Field is then configured as its primary sort Field. When clicking it again, its primary sort Field, ascending or descending, is then reversed.
When clicking a column's header with the SHIFT key pressed, its associated Field is then configured as its secondary sort Field. When clicking it again with the SHIFT key pressed, its secondary sort Field is then reversed.
The EnableSortMarker property allows displaying or hiding an indication of ascending or descending sort order when clicking a column's header.
For more information about this behavior, please check E3Alarm's EnableSortMarker, PrimarySortAscending, PrimarySortField, SecondarySortAscending, SecondarySortField, ThirdSortAscending, ThirdSortField, FourthSortAscending, FourthSortField, and BannerMode properties on the Elipse E3 Reference and Scripts Manual.
Sorting example
