E3Alarm |
An E3Alarm monitors active or unacknowledged Alarms in an application. With this object, users can check the status of Alarms, as well as acknowledge them manually.
E3Alarm
To use this object, follow this procedure:
1.Right-click a Screen or the working area and select the Insert - E3Alarm option or click E3Alarm on the toolbar of that Screen.
Inserting an E3Alarm on a Screen
Some of this object's properties can be configured via Properties List, without creating scripts for this. To configure any property, just locate it on the Properties List and perform the necessary adjustments.
