OPC UA Folder |
An OPC UA Folder object defines groups or subdirectories, for a better organization of variables. Each OPC UA Folder can be renamed as needed, and new OPC UA Folders can be inserted inside each others. At run time, if an OPC UA Folder is disabled, all its content is deactivated. To use this resource, follow this procedure:
1.Right-click an OPC UA Subscription object and select the Insert - Folder option.
Inserting an OPC UA Folder
