OPC Folder |
An OPC Folder defines groups or subfolders for a better organization of variables. Each OPC Folder can be renamed as needed, and new OPC Folders can be inserted inside one another. If an OPC Folder is disabled at run time, its whole content is deactivated. To use this resource, follow this procedure:
1.Right-click an OPC Tag Group and select the Insert - New Folder option.
Inserting an OPC Folder
