Drivers
Drivers
Elipse E3 allows communication with data acquisition devices, controllers, PLCs (Programmable Logic Controllers), RTUs (Remote Terminal Units), or any other type of device, by using its own I/O Drivers or OPC Servers, according to the type of device or communication needed.
NOTE
Driver objects (I/O Driver, I/O Folder, I/O Tag, I/O Block, I/O Block Element, OPC Driver, OPC Tag Group, OPC Folder, OPC Tag, OPC Block, OPC Block Element, OPC UA Driver, OPC UA Subscription, OPC UA Folder, OPC UA Tag, OPC UA Block, and OPC UA Block Element) can be configured to work as Alarm Areas.
All options of Driver's object views that are available via contextual menu, by using the right mouse button, are also available by using the shortcut key SHIFT + F10, which corresponds to the application or menu key Application or menu key.
The Properties Window of Driver objects in object Views can be opened by using the shortcut keys ALT + ENTER or ALT + Double-click.
