Hot-Standby |
A remote connection to the Domain supports Hot-Standby Domains natively. To do so, specify two different server names, main and backup, in their respective items in the Identifying servers in the network field, on Remote Domains tab. Users must notice that, for a proper usage of Hot-Standby, these names must be the same ones configured by the Remote Domain being accessed. Once this configuration is performed at run time, the E3 Server constantly tries to connect to both servers, routing access of all Application.GetObject methods and Links to the first accessible server, and that indicates it is executing the Domain. In case the server names change when the Client Domain is executing, it disconnects and restarts the connection with these new servers.
