Monitor
Monitor
The E3 Admin - Monitor window shows real-time information about the status of Domain servers. To do so, right-click the E3 Admin icon on Windows Notification Area and then select the Monitor Monitor option.
Available options on the E3 Admin - Monitor window
Option
Description
Current domain
Name of the active Domain
Ping addresses
List with all ping server addresses
Name
Server's name
Address
Server's network address
Ping
Shows network ping status with this server
Clock
Shows server's local time
State
Shows Domain status on the server (Stopped or Running)
Connection
Shows the status of the DCOM connection with the server
Role
Shows a list of functions reported by the server. Possible values are Active: This is the Domain's active server, Standby: This is the Domain's standby server, Failure(n):The server has local failures reported, Priority: The server requested priority to execute the Domain. This indication forces the active server to switch to Standby mode, Candidate: The server is a candidate to execute the Domain, or E/S: The server contains active IOServers
