Projects Tab
Projects Tab
Users can add, remove, or edit projects (.prj files) of a Domain. To open this item, right-click the E3 Admin icon on Windows Notification Area, select the Domain - Options Domain - Options option to open the window on the next figure, and then click the Projects tab.
Projects tab
Projects tab
Available options on the Projects tab
Option
Description
Name
This option lists all names of projects in an application
Add and Remove
By using these options, users can remove or add projects in an application. To add a project, click Add and then fill in the Project Name field. To remove a project, select it and then click Remove. The PRJ file is not deleted from disk, only from Domain's project list
Project Name
Type the name of a project file, which must be a path relative to Domain's directory, that is, the directory containing the .dom file, such as Screens.prj or Hydro\Station1.prj
Maintenance mode (disabled)
This option allows disabling project's execution, thus avoiding errors when a Domain is executed. When this option is enabled, the icon Project disabled indicates this project is not used. Projects displaying an icon Project enabled are enabled and are executed
