System Events Recording |
Message generated whenever a change in the options of the Events recording tab on the Domain Configuration window happens. The available macros on this message are:
•%USER% contains the name of the user who changed the Events recording tab
•%SESSION% contains "E3 Server"
•%MACHINE% contains the name of the computer where the Events recording tab was changed
•%CAUSE% contains a detailed message about this modification. Please check topic Event Causes for more information
