Manual Server Switch |
Message generated whenever the activation of a Domain's backup server is forced, via the Server - Activate option on E3 Server menu. The available macros on this message are:
•%USER% contains the name of the user who activated the backup server, or "Anonymous" if no authentication was requested when that server was activated
•%SESSION% contains "E3 Server"
•%MACHINE% contains the name of the computer where the command to activate the backup server was generated
