Domain Security |
Message generated whenever a change in the options of the Security tab on the Domain Configuration window occurs. The available macros on this message are:
•%USER% contains the name of the user who changed the Security tab
•%SESSION% contains "E3 Server"
•%MACHINE% contains the name of the computer where the Security tab was changed
•%CAUSE% contains a detailed message about this modification. Please check topic Event Causes for more information
