Database |
An Elipse E3 Database is used to store project information regarding Historic objects, Formulas, Alarms, and Storage and it supports Access, Oracle, SQL Server, PostgreSQL, and MySQL databases.
To use this feature, right-click the project's name in Explorer mode and select the Insert - Database option. In Domain mode, right-click the Server objects - Databases option, select the Insert Database In option, and then the project's name.
Inserting a Database in Domain mode
When users insert a Database in an application, some options regarding Data Server types are enabled, via Configuration tab on Properties Window, or via SourceType property on the Properties List.
Some of this object's properties can be configured via Properties List, without creating scripts for this. To configure any of these properties, locate it on the Properties List and perform the necessary adjustments. The description of the properties of this object can be found on the Elipse E3 Reference and Scripts Manual.
NOTE |
A Database object can be configured to work as an Alarm Area. |
