Internal Tag |
An Internal Tag is a general-purpose object, used to store values of any type, including numbers, texts, and even other objects. To use this object, follow these procedures:
1.Right-click a Data Server and select the Insert - Panel - Internal Tag option.
Inserting an Internal Tag
The system opens up a window asking the number of Tags to create in the Server, as well as their names. This name are auto-incremented and, if this option remains blank, Tags are created with a default name.
Adding Internal Tags
Some Internal Tag properties can be configured using the Properties List, without creating scripts for this. To configure any property, just locate it on the Properties List and perform the necessary adjustments.
