Data Server |
Data Servers are objects responsible for executing system variables, such as Internal, Demo and Timer Tags, as well as XFolder and XObject instances. To use this feature, follow this procedure:
1.Right-click the project in Organizer and then select the Insert Data Server in option.
Inserting a Data Server
NOTE |
•Data Server objects (Data Folder, Counter Tag, Demo Tag, Internal Tag, and Timer Tag) can be configured to work as Alarm Areas. •All options of Data Server's object views that are available via contextual menu (by using the right mouse button) are also available by using the shortcut key SHIFT + F10, which corresponds to the application or menu key . •The Properties Window of Data Server objects in object views can be opened by using the shortcut keys ALT + ENTER or ALT + Double-click. |
