Rate-of-Change Alarm
Used to monitor quick variations in a process variable. A Rate-of-Change Alarm Source uses its values specified in variable's units per second.
Rate of Change tab
Rate of Change tab
Available options for the Rate of Change tab
Option
Description
Enable
Enables a Rate-of-Change Alarm
Change/second
Indicates the percentage of the monitored variable that can vary per second. This value is calculated based on each variable's reading interval, using the formula ROC = (Current Value - Previous Value) / (Current Instant - Previous Instant). If this rate of change is greater than the specified rate, it is considered in an alarm status
Message text
Allows specifying a text displayed to users when this Alarm is in an active condition
Severity
Specifies an Alarm level's severity. Available options are Critical, High, Medium, or Low
Need Ack
Enables or disables Alarm acknowledgment
Delay (ms)
Specifies a delay time, in milliseconds. When this value is equal to 0 (zero, default), no delay is applied
Return message
Allows specifying a text message displayed to users when this Alarm returns to its normal status
Allow shelving
Enables or disables shelving this Alarm
Maximum shelving time
Maximum time, in minutes, this Alarm can remain shelved. Default value of this option is 60, that is, one hour
Maximum shelve count
Maximum number of times this Alarm can be shelved. Default value of this option is 0 (zero), that is, no limit
