User Fields Settings |
The User fields tab allows adding arbitrary values to Alarm Events.
User fields tab
Available options on the User fields tab
Option |
Description |
Name |
Specifies this Field's name |
Type |
Specifies this Field's type. Available options are 0: String, 1: Integer, 2: Double, or 3: DateTime |
Size |
Specifies this Field's size |
Source |
Specifies this Alarm's data source |
Propagate? |
Forces an immediate update on all Alarms that inherit this User Field's value, whenever it receives a forced value or if its Link changes |
Adds |
Adds a User Field to the end of this list |
Delete |
Deletes the last User Field from this list |
User Fields can only be included to or excluded from the end of this list. Excluding User Fields from this list reflects on all Alarm Areas and Sources related to this Alarm Server, but only if the deleted Fields were not configured with a forced value or a Link. Otherwise, these Fields still appear on Alarm Areas and Sources. The next figure shows an Analog Alarm with User Fields inherited from an Alarm Server.
Inherited User Fields
User Fields can be copied and pasted between objects. To do so, configure the User Fields, right-click the object and select the Copy User Fields option. Then, right-click the destination object and select the Paste User Fields option, according to the next figure.
Options to copy and paste User Fields
NOTES |
•Whenever an object contains forced values in User Fields, that is, values not inherited from upper Areas, a message is displayed asking for confirmation to overwrite these values. •For more information about the behavior of a User Field from Alarm Areas and Sources, in Elipse E3 Studio and at run time, please check the Link, Value, and ValueSource properties on Elipse E3 Reference and Scripts Manual. |
