Alarm Server |
An Alarm Server object centralizes all Alarms in a project. In it, users can find the total number of active Alarms in an application, acknowledged or not. This object is also responsible for reporting Alarm Events to all connected Elipse E3 Viewers, as well as sending these Events to a database, if necessary.
An application can only have one object of this type, and its presence is mandatory to perform an Alarm verification. To insert an Alarm Server, follow this procedure:
1.Right-click the project's name in Explorer mode and select the Insert - Alarm Server In option. In Domain mode, right-click the Server objects - Alarms item, select the Insert Alarm Server In option, and then the project's name.
Inserting an Alarm Server in Domain mode
