Alarm Configuration |
An Alarm Configuration object is where Areas are inserted and organized. To insert this object in a project, follow this procedure:
1.Right-click the project's name in Explorer mode and select the Insert - Alarm Configuration In option. In Domain mode, right-click the Server Objects - Alarms item, select the Insert Alarm Configuration In option, and then the project's name.
Inserting an Alarm Configuration object
NOTES |
•All options of Alarm Configuration's and Alarm Area's object views that are available via contextual menu, by using the right mouse button, are also available by using the shortcut key SHIFT + F10, which corresponds to the application or menu key . •The Properties Window of Alarm Configuration and Alarm Area objects in object views can be opened by using the shortcut keys ALT + ENTER or ALT + Double-click. |
