Microsoft Forms |
To insert one of the Microsoft Forms previously registered in Elipse E3 on an application, there are two options:
1.Right-click a Screen and select the Insert - MSForms option.
2.Select the intended object on the toolbar of that Screen and click the Screen to establish the object's initial point, dragging the mouse diagonally until the object reaches the desired size and position.
The objects from Microsoft Forms library that are available in Elipse E3 are described in the next sections.
