Driver's Revision History
Version
Date
Author
Comments
2.1.2
06/30/2026
M. Ludwig
•Driver updated to IOKit library version 3.0 and Visual Studio 2022 (Case 38070).
2.1.1
05/29/2013
G. Taschetto
•Driver converted to IOKit version 2.0 (Case 13525).
•Removed a false error message (Case 11576).
•Fixed syncing problems (Case 11574).
2.0.1
01/16/2007
M. Salvador
•Driver converted to IOKit library (Case 6979).
•Added support for Ethernet TCP/IP communication (IOKit).
•Added support for Modem RAS communication (IOKit).
•Added support for Strings and Superblocks (Elipse E3 version 2.2 build 127 or later).
•Driver renamed from Telway32.dll to UniTelway.dll.
1.1.1
05/15/2006
C. Mello
•Added the %MD Double Word data type, that is, the N2 or B2 parameter equal to 5 (five) (Case 5742).
1.0.1
10/08/2003
•All versions before revision control.
