Driver Revision History
Version
Date
Author
Comments
2.0.1
12/22/2025
M. Ludwig
•Driver updated to IOKit library version 3.0 and Visual Studio 2022 (Case 38690).
1.4.1
11/18/2010
C. Mello
•Fixed a communication problem with Tags from the IOKit library with Superblocks enabled (Case 11056).
1.3.1
04/16/2009
C. Mello
•Added compatibility with Windows CE (Case 9826).
1.2.1
06/23/2008
A. Quites
•Added support for MMC cards (Case 8841).
1.1.1
09/10/2007
A. Quites
•Added support for clock writing in Elipse SCADA using the attribution of CurrentTime and GetTime (Case 7544).
•Implemented reading and writing real numbers (Case 8690).
•Implemented the Superblock feature (Case 7844).
•Fixed a problem in the command to set a clock, which was sending an inverted year (Case 7527).
1.0.1
08/20/2006
A. Quites
•Initial version of this Driver (Case 5729).
