Profile Parameters Inherited from SuperDriver
The next parameters are copied from the configuration of Elipse SuperDriver Driver to all its subordinated Profiles, therefore they do not need to be filled in all Profiles.
•Setup tab:
•Physical layer: Fixed as Ethernet and does not expect communication using other interfaces
•Connection management mode: Automatic or Manual
•Retry failed connection every n seconds
•Give up after n failed retries
•Disconnect if non-responsive for n seconds
•Activation and Log file name: Generates a log file for each Slave, whose file name is formed by the name configured in Elipse SuperDriver Driver and by a suffix formed by the Profile name and TCP/IP Port
•Ethernet tab:
•Transport (protocol): Fixed as TCP and does not expect another transport protocol
•Main IP address
•Backup IP address
•Local port specification (for main IP, as well as for backup IP)
•Ping: Enabling, time-out, and retries
NOTES
•The other settings on the Setup and Ethernet tabs of Elipse SuperDriver Driver are ignored and each Profile apply their own settings.
•The TCP/IP port on the Ethernet tab is not considered. This parameter is specified in the Tags.
