Driver's Revision History
Version
Date
Author
Comments
2.1.10
08/06/2026
M. Ludwig
•Driver updated to IOKit library version 3.0 and Visual Studio 2022 (Case 38047).
2.1.7
02/13/2017
M. Ludwig
•Fixed a failure when finishing in stress conditions (Case 21663).
•Fixed a problem that triggered more than one collecting simultaneously on the same Profile or TCP/IP port, which may cause a GPF (Case 21751).
2.1.4
10/17/2016
M. Ludwig
•Fixed a lack of loading configurations in Driver Profiles for Slaves (Case 21664).
•Driver ported to IOKit library version 2.0.72 (Case 21634).
2.1.2
03/17/2015
M. Ludwig
•Implemented a withdrawal of communication retries if a device is detected as in Offline mode (Case 18356).
•Implemented an overwriting of Ethernet configurations to avoid a triggering of an unwanted automatic redundancy in General Scan mode (Case 18389).
2.1.1
11/14/2014
M. Ludwig
•Implemented a maximum limit of concurrent communications (Case 15645).
•Changed the limit of Slaves to 1000. When reaching this limit, this Driver does not create more Slaves (Case 17564).
2.0.5
03/21/2014
M. Ludwig
•Added a limitation for Slave connections (Case 15976).
2.0.4
11/21/2013
F. Englert
M. Ludwig
•Fixed the possibility of a failure when closing this Driver (Case 14855).
•Implemented a second call for writings after executing a reading process (Case 15176).
2.0.3
09/27/2013
F. Englert
•Added Tags for collecting statistics (Case 14954).
2.0.2
09/23/2013
F. Englert
M. Ludwig
•Fixed memory leaks (Windows heaps) during execution (Case 14918).
•Driver ported to IOKit library version 2.0 (Case 13888).
•Implemented the generation of logs from sub-Drivers in different files (Case 13890).
•Elipse SuperDriver Driver now only loads Drivers supporting multiple instances on the same process (Case 13995).
1.2.2
03/05/2013
M. Ludwig
•Changed the waiting behavior when finishing (Case 13139).
•Fixed the update of parameters at run time (Case 13358).
•Fixed a lack of resource releasing when writing I/O Tags (Case 13484).
•Fixed an indefinite growth of resources usage when the ErrorHistory Tag is not read (Case 13477).
•Fixed an incorrect loading of IP addresses configured on the properties window (Case 13476).
1.1.1
05/31/2012
C. Mello
•Added a service for writing Tags for Driver Profiles with Tags in Advise mode (Case 12521).
1.0.1
09/22/2011
M. Ludwig
•Initial version of this Driver (Case 11581).
