Clock Syncing: Date and Time
Read-Only
N1
Address of a slave. Use the value 900 for a broadcast address
N2
0 (zero)
N3
17
N4
Additional time, in milliseconds
Every reading operation in this Tag sends a clock syncing command to a slave, syncing that slave's internal clock with the computer's clock. The category used is D. To compensate any network delay when sending a command, users can define an additional time to add to the computer's time in the N4 parameter. The Value property is not used and returns 0 (zero) in Broadcast mode.
