Last Events of the Backup Buffer
Reading and Writing
B1
Address of a slave. Use the value 900 for a broadcast address
B2
0 (zero)
B3
10
B4
0 (zero)
Corresponds to the B category. Allows reading the most recent events of the buffer of a slave. When an event is read as a PLC Tag, this event is returned as a String. For more information, please check topic Reference for PLC Tags. When reading as a Block Tag, events are returned with the following Elements:
•Element 0: Timestamp
•Element 1: Channel
•Element 2: Code of an event
The Timestamp property returns the same value of Block Element 0 (zero).
