Event Conditions |
B1 |
Address of a slave. Use the value 900 for a broadcast address |
B2 |
Channel |
B3 |
13 |
B4 |
0 (zero) |
Corresponds to the V category. It reads event conditions from internal variables of a slave into a Block Tag. The first Block Element is returned in Date and Time format. The other Block Elements are returned in 32-bit floating point format.
