Driver Settings
Driver Settings
Callback
For this Sigfox Driver to work properly, users must configure a Sigfox 0G Technology service to send Callbacks to a specific IP address, which is the IP address of a machine executing an Elipse Software application with this Driver. This Callback must send HTTP requests to the configured TCP/IP port in this Driver, which is in listen mode at run time waiting for data.
HTTP requests must always use a GET method containing "host" and "user-agent: SIGFOX" fields. This GET method must also end with a double line break, that is, two combinations of CR and LF characters. The variables containing values must be in the URL field of the HTTP request.
All configurations must be performed on this Driver's properties window, specially on the Sigfox tab. For more information about the Setup tab, please check topic Documentation of I/O Interfaces. The available options to configure a Sigfox Driver on the Sigfox and Setup tabs are described on the next topics.
