Strings Parameterization
The SCPI Driver supports configuration of Tags by Strings, when used in Elipse E3, in Elipse Power, or in Elipse Water. This configuration is performed in the ParamDevice and ParamItem properties of an I/O Tag, and also using the N4 parameter.
ParamDevice property
SCPI command
ParamItem property
Parameters of an SCPI command (optional)
N4 or B4 parameter
Return type. Possible values are 0: Auto, 1: Double, 2: Integer, or 3: ASCII
So, at each reading or writing to a Tag, a command is sent with the specified parameters. The return is handled according to the N4 or B4 parameter, if available. Examples:
•Sending a FUNC:PULS:DCYC writing command with the ParamItem property equal to 65:
•ParamDevice property: FUNC:PULS:DCYC
•ParamItem property: 6 (six)
•N4 parameter: 0 (zero)
•Sending a MEAS:RES? reading command and automatically handling the return:
•ParamDevice property: MEAS:RES?
•Sending a CONF:CAP reading command, followed by a READ? command, and then handling the return as a Double value:
•ParamDevice property: CONF:CAP;READ?
•N4 parameter: 1 (one)
