I/O Tag
I/O Tag
Reading and Writing
N1
Identifier of a command
N2
0 (zero)
N3
0 (zero)
N4
0 (zero)
Value property
Parameters of a command. NOTE: Only for writing commands
Writing Commands
The value passed to a Tag must have a String data type. It is recommended to use the CStr method in Links and scripts.
When writing a value to a Tag from a writing command, this Driver sends that command to a remote device. In case a command's Append Value option is selected, this Driver concatenates the value written to a Tag at the end of a command. Usage examples:
Application.GetObject("Driver2.Tag3").WriteEx "ON", Now, 192
Application.GetObject("Driver2.Tag3").WriteEx "OFF", Now, 192
Application.GetObject("Driver2.Tag4").WriteEx CStr(Screen1.Item("Setpoint1").Value), Now, 192
