Tag Reference
Tag Reference
This section contains information about the configuration of Tags of this Driver. All SBUS commands were implemented in this Driver and are referenced in Tags by using numerical parameters, the [N/B] parameters, or by using syntactical parameters, the String-type parameters.
Syntactical Addressing Fields
The Device field must obey the syntax <Subnet ID>.<Device ID> and the Item field must obey the syntax <Command>:<Auxiliary parameter>, in which <Command> refers to the name of a Tag, according to its respective function. Possible values are the following:
•SBus.Scene
•SBus.Series
•SBus.TimerSwitch
•SBus.UniversalSwitch
•SBus.SingleChannel
•SBus.CurtainSwitch
•SBus.InfraredSwitch
•SBus.GPRSSwitch
•SBus.PanelSwitch
•SBus.Temperature
The <Auxiliary parameter> value must be separated by a colon and contain a number, as described in each Tag.
Numerical Addressing Fields
N1 or B1
Command
N2 or B2
Destination Subnet ID × 256 + Destination Device ID
N3 or B3
Auxiliary parameter
N4 or B4
Not used, leave it in 0 (zero)
