Configuring Properties |
This topic contains information about the properties available on the RSSP_I_Server tab, already including the value of offline property Strings, which can be user-programmed when starting an application in Offline mode.
For Elipse E3, Elipse Power, or Elipse Water applications, the value of these settings can also be defined at run time. To do so, start this Driver in Offline mode by selecting the Start driver OFFLINE option on the Setup tab of the properties window. The configuration options of this Driver are described on the next table.
Configuration options for CRRC RSSP-I Server Driver
Tab |
Parameter |
Offline String |
Data Type |
Description |
Setup |
Physical Layer |
IO.Type |
Text |
By default, use the Ethernet option |
Timeout |
IO.TimeoutMs |
Number |
A time limit, in milliseconds, to receive data from a device's response. For example, the value 1000 defines a one-second limit |
Ethernet |
Transport |
IO.Ethernet.Transport |
Text |
By default, use the UDP option |
Accept Connection |
IO.Ethernet.AcceptConnection |
Number |
Enables or disables the listening mode via Ethernet. The available options are 0: Disabled or 1: Enabled |
Listen IP |
IO.Ethernet.ListenIP |
Text |
IP address for the listening mode, in the format [0-255].[0-255].[0-255].[0-255] |
Listen Port |
IO.Ethernet.ListenPort |
Number |
Ethernet port for the listening mode |
RSSP_I_Server |
My ID |
RSSP_I_Server.MyID |
Number |
Sets the source identifier for this Driver in the RSSP-I protocol |
Broadcast DC2 |
RSSP_I_Server.IpBroadcast |
Number |
Defines the UDP/IP network mask for broadcasting a DC2 (Communication Request Frame) initialization message |
SDI Message timeout (ms) |
RSSP_I_Server.SDIMessageTimeout |
Number |
Defines the time interval, in milliseconds, that this Driver waits to receive SDI (Station Information Frame) messages. If this time expires, the protocol is restarted by the DC2 (Communication Request Frame) message |
Semaphore Data items |
RSSP_I_Server.SemaphoreDataItems |
Number |
Number of Semaphore Data-type data items delivered by an SDI (Station Information Frame)message |
Switch Data items |
RSSP_I_Server.SwitchDataItems |
Number |
Number of Switch Data-type data items delivered by an SDI message |
Section Data items |
RSSP_I_Server.SectionDataItems |
Number |
Number of Section Data-type data items delivered by an SDI message |
Light Data items |
RSSP_I_Server.LightDataItems |
Number |
Number of Light Data-type data items, in bytes, delivered by an SDI message |
Flag Data items |
RSSP_I_Server.FlagDataItems |
Number |
Number of Flag Data-type data items delivered by an SDI message |
Notify Data items |
RSSP_I_Server.NotifyDataItems |
Number |
Number of Notify Data-type data items delivered by an SDI message |
Command Confirm |
RSSP_I_Server.UseCommandConfirm |
Number |
Enables or disables the presence of Command Confirm-type items in an SDI message. Possible values are 0: Disabled or 1: Enabled |
Power-On Time Counter |
RSSP_I_Server.PowerOnTimeCounterDataItems |
Number |
Number of Power-On Time Counter data items delivered by an SDI message |
All offline properties must be configured via PLC Tags in String format using the N1 parameter equal to -1 (minus one), the N2 parameter equal to 0 (zero), the N3 parameter equal to 0 (zero), and the N4 parameter equal to 3 (three). For more details and examples, please check topic Documentation of I/O Interfaces.
